overheating
Old Sep 13, 2009 | 09:59 AM
T-BEEF's Avatar
Default overheating
Hi guys I do a lot of mud and my rad plugs then the overheat. Seems only tobother the polaris. Is there an aftermarket rad with larger fins or an oil cooler available. Any other thoughts are welcome.(2007 500 x2)
Old Sep 13, 2009 | 12:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it doesnt happen only to polaris. my buudies BF750 has done it as well as another BF650. check out how small those fins are compared to polaris. thats why i built a trailside washer to use when we went mudding to clean it out before it dries like cement and hard as hell to get it out.
Old Sep 13, 2009 | 09:11 PM
carlobee's Avatar
oh. i'd better be careful on mine this time.
Old Jan 3, 2010 | 09:04 PM
pedals's Avatar
Default how to stop the overheating
I was also wondering the same thing. It looks like theres lots of things in the way around the winch and infront of the rad on my 08 polaris sportsman...is there any of this people have removed to let the air flow in more when your out mudding...I've also seen a guy just put the whole rad up on the front rack. It makes it impossible to open the front storage but he said he never had an overheating problem after doing it!
Old Jan 4, 2010 | 05:22 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if your going to be doing hard core mudding there isn't much you can do besides relocating the rad. to prevent a build up of mud in which you NEED to clean after every ride and once the mud is baked inthe radiator it is sometimes very hard to clean it back to front which you will need to do or it will overheat eventually. imo
Old Jan 4, 2010 | 06:06 AM
switzomatic's Avatar
I agree with Sten. Also remember that where there's mud, there's water. Run it back and forth in the water from time to time and that will really help. Never had a problem with overheating after running around in some water occasionally(and the frequent beer breaks probably helped too).
Old Jan 4, 2010 | 01:16 PM
4getful2's Avatar
it's hard to get all the goo cleaned out from the front ,i usually go thru the opening where the fan blades are .
Jenn1
Sep 8, 2015 09:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
