Gas tank removal on raptor
i have already took out all the bolts holding it on and the plastic. but i am haveing trouble disconnecting the fuel line from it. do you disconnect it from the on off res switch. or do you remove the switch from the gas tank.
i am trying to get it ready before someone comes and helps me put in my jet kti this evening
any suggestions
any suggestions
3 bolts hold on the tank. You want to disconnect the fuel line going to the carbs from the on/off valve. Just be sure and turn off the gas first. If it is hard to get the fuel line off of it, you may have to take some needle nose pliers and gently (be careful not to tear) wiggle/turn the hose back and forth. Sometimes they seem to be frozen to the male end.
