Need help with 97 300 trx. No Fire.
Old Sep 16, 2009 | 02:29 PM
firefighter8518's Avatar
Cool Need help with 97 300 trx. No Fire.
Just got through replacing the one way clutch on my 300 fourtrax and now it wont start. Honestly i didnt try and start it before i began the project. Im pretty sure theres nothing i could have messed up on the crank case side. I have the Clymer Manual but was hoping that someone had maybe already had and fixed a firing problem. I hooked a fluke multi-meter to the batt and kick started it. I do get a voltage spike, so that tells me the alternator is working. Am i looking at a pulse generator problem or an ignition coil problem? Any help would be great. Thanx
Old Sep 16, 2009 | 03:01 PM
dirtjunkie's Avatar
It could be either, but more likely going to be the pulse generator pickup coil.
Old Sep 16, 2009 | 05:07 PM
Thumbs up Fixed it
I figured out what was wrong and u wont believe it. The plug for the neutral indicator light wasn't securely on the pin. The plugs are located on the outside of the crank case cover, which i had to remove and reinstall. So looks like it was my fault after all. But for future reference to all those with a 3oo trx. Make sure you check all plug connections on the crank case side of the engine behind the black metal cover before you jump to conclusions about a firing problem.
flyin-lowe
Dec 1, 2017 03:18 AM
j.graul84
1) Engine problems..
Nov 6, 2015 08:42 AM
JakeXBL
Sep 5, 2015 01:08 PM
cornermike
Jul 30, 2015 06:37 AM
toonces
Jul 24, 2015 09:03 AM
