Can't get 07 800 started
Old Sep 19, 2009 | 07:43 AM
turbo777's Avatar
Default Can't get 07 800 started
I can't seem to get my 07 800 started. It seems that the battery won't hold a change at all, I can't even get it started with the starter connected. I tried to jump it, but it just clicks when I do that. Any ideas? Is it the battery, or something else?
Old Sep 19, 2009 | 07:56 AM
popoman's Avatar
clicking is the solenoid. sounds like the starter may be bad, or the battery very weak. if it doesnt attempt to start while jumping it would make me lean more towards the starter... i would check all connections at the battery and at the solenoid all the way down to the starter to make sure nothing is loose.
sometimes tapping/hitting the starter with something can make it work again.... if that makes it work i would then replace it. i had to do this on my 400 2 stroke, it worked for a couple times after that lol... what happens sometimes is the brushes get worn down, hitting it frees them up slightly to make better contact with the armature.
Old Sep 19, 2009 | 08:07 AM
turbo777's Avatar
Do you think it could be both the starter and the battery? I know the battery won't hold a charge, because after charging it over night on 2 amp, it still won't even light up the display. Maybe I will start with the battery today, and then go from there.
Old Sep 19, 2009 | 08:34 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
DOA on the battery, if no charge can be held. Check around, good deals, Poo gets around $140. Check Batteries Plus and others, and its not your standard ATV battery
Old Sep 19, 2009 | 08:40 AM
popoman's Avatar
if it wont even light the display after charging definately need a battery... i missed that in your first post. im sure the starter will be fine after that...
still surprized it didnt crank at all trying to jump it. did you try to jump it off the charger or a car/atv?
Old Sep 19, 2009 | 08:45 AM
turbo777's Avatar
I jumped it off the charger at 50 amps, and with a car.
Old Sep 19, 2009 | 06:16 PM
turbo777's Avatar
Is there any way to add water to a sealed battery. I think the answer is NO, but wanted to ask.
Old Sep 19, 2009 | 07:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
no way to add liquide to a sealed battery. just replace if battery wont hold a charge.
Old Sep 19, 2009 | 07:35 PM
rkuhnjr's Avatar
A battery with a bad cell will suck the jump which is probably what is happening here since the battery actually doesnt sound that old.
When you try to jump a bad cell it just sucks up all the juice.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
