ADC Grinding Noise - 800 Sportsman
Old Sep 21, 2009 | 10:45 AM
Rcher's Avatar
Exclamation ADC Grinding Noise - 800 Sportsman
2007 Sportsman 800
When I engage AWD the active descent control kicks in under 15 mph. I am hearing a grinding noise when ADC is working under 15 mph. I hear it when descending steep grades. I do not hear a noise when powering or above 15 mph. It seems to be consistent with the ADC.
I have checked ADC fluid and front transfer case, all is full and in accordance with the manual. I am using the proper fluids. The ADC works, it just makes a horrible grinding noise under 15 mph while slowing.
Help?
Old Sep 21, 2009 | 02:59 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if i remember right it only works under 15 mph or w/ no throttle used. has the fluid been changed? just wondering if any metal was seen in it? mine doesnt make any noise when its working and i gave it an exteme work out a few ekks ago coming down huge sleep mts. w/ 2 people as well.
Old Sep 21, 2009 | 09:02 PM
UTU's Avatar
UTU
Default adc
only time i have seen this is air in the system got to bleed it......
Old Sep 21, 2009 | 09:55 PM
Rcher's Avatar
How do I bleed the ADC system?
Old Oct 4, 2009 | 08:14 AM
tpc13's Avatar
Default ADC grinding
Mine does the same thing and I also checked the fluids and they appear to be full. someone on this forum suggested I replace the fluids and see if that helps. Also how do you bleed the system? as someone above suggested. Just replace the fluids or what?
Old Oct 4, 2009 | 08:57 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
here you guys go. hopefully you can read it as i did it real quick.
Divergent12
Dec 30, 2017 08:33 PM
ronnierhino06
Nov 9, 2015 12:56 PM
austinwhitton
Aug 11, 2015 06:21 PM
ghost civic
Jul 19, 2015 10:13 AM
D-Hagz
Jul 4, 2015 02:19 AM
