Check engine light?
Old Sep 21, 2009 | 09:12 PM
Oldman800's Avatar
Default Check engine light?
Last week while we on our big trip to Hatfield McCoy for a week my check engine light came on. I noticed when we rode into Mann, it was off. Back on the trails for a ride to Gilbert it came on again. In Gilbert, it went off. Back on the trail to return to Browning Fork Trailhouse where we stayed, back on. After thinking about what was in common with riding the streets vs the trails I realized in town I had the AWD off, so I tried it. Sure enough, in gear AWD on check engine light on. In gear AWD off no light. Neutral or park, no light either way. Dummy me, I left my owners mannual at home, and didn't know how to check for codes. We rode Sun-Fri, but by wednsday, it did not come on anymore. The book says it comes on whit a problem in the EFI, I don't know why the AWD would bring it on.
Old Sep 21, 2009 | 11:38 PM
reno82's Avatar
It could be a ground short, is it stumbling at all? Check the battery terminals to make sure they are tight. It's could also mean it's time for service. The light comes on for awhile when you first start it to remind you it's time for service, I think it's set for 50 hours. The manual tells you how to shut it off, but mines not handy. If it's running fine, just ride till you get home.
Old Sep 22, 2009 | 05:47 AM
TheATVSuperStore.com's Avatar
Former Sponsor
I had the exact same problem with my 2008 SP800 when I went to Harlan KY for the Rincon Ride this summer. When I started to climb the steep mountain trails I put it in atv. When I reached the top the check engine light was on. I found that it would come on a few minutes after engaging awd. As soon as I turned the awd off the check engine light would also turn off. I never found the issue with it. When I retruned home it never happened again around the house. I never found a bad code on the system. Could it possibly have to do with the altitude change? Just a thought.
Old Sep 22, 2009 | 01:26 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
as i understand this awd on the newer bikes you can leave them in awd all the time and it only kicks in when it sensors wheel spin of 1/5 of a turn, so it wouldnt matter where you were riding. maybe a sensor?? as it's hard to tell. was the awd workng correctly?
Old Sep 22, 2009 | 02:33 PM
Former Sponsor
On mine yes the 4x4 was working. It worked the intire trip.
Old Sep 22, 2009 | 02:51 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
in the dianostic mode you can scan through to the awd on section and it says on/off(i think anyways) and was wondering if you checked it if it would show the check light? could be a faulty circuit or something?
Old Sep 22, 2009 | 03:03 PM
Former Sponsor
When I came home I did a scan but nothing showed up.
Old Sep 22, 2009 | 08:13 PM
Oldman800's Avatar
Mine to. AWD worked when needed, and Active Decent Control ( 4 wheel engine breaking ) worked as well.
Old Aug 24, 2020 | 11:20 PM
Jake_71's Avatar
Mine just started doing this too. I don't know that this is the issue, however I saw someone else posting that it turned out to be a bad transmission position selector switch.
SOLOLUCKY
Oct 4, 2024 09:09 PM
Dabears1983
Jun 16, 2015 12:17 PM
Trxoutlawz
Mar 2, 2001 09:33 AM
in2atvn
Sep 20, 2000 04:58 AM
JRM
Nov 19, 1999 01:41 PM
