Cooling fan runs continuesly
Old Sep 24, 2009 | 07:27 PM
Bolt Uptight's Avatar
Default Cooling fan runs continuesly
Evening all....my problem is my hot,check engine light stated blinking and fan will not shut down even when key is off.Just pulled thermostat and checked,it opens and closes...pan of hot water test.Ran bike with no thermostat in it,both hoses and rad got warm but not hot,any ideas?
Old Sep 24, 2009 | 07:45 PM
Shorted heat sensor on cylinder can cause fan and hot light problems. Also ecm modules on certain machines can do the same. What year and model?
Old Sep 24, 2009 | 07:55 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if it an 05',06' it might just be one of the bad ecm's. if so there is a recall on most of the models and a dealer could run your vin# to check. imo.
Old Sep 25, 2009 | 05:01 AM
It's a 07 model
Old Sep 25, 2009 | 10:47 AM
It's a 07 model
Whether a 500 or 700?? both have a temp sensor on block that can short out and cause fan to stay on and hot light also. Radiator sensor can be a problem also. You can check the sensor with an ohm meter when cold and then when warm see if readings are different. If doesnt vary or shorted out,then replace.If checks out ok then possible radiator sensor. Be a little more specific on the machine you have so posters can help you!! Good luck OPT
Old Sep 25, 2009 | 10:53 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
My second ECM did that even with the Quad sitting for over 4 hours and the engine cold............I was Bar-b-que'ing when I noticed my issue.
...Caper...........My is a 2006 Sp 450......
Old Sep 25, 2009 | 12:45 PM
thatshortkid92's Avatar
it can range from all that to just simply cleaning off the battery post. if it where me i would try that then resort to do everything else.
Old Sep 25, 2009 | 01:46 PM
With the key off(fan running) ..The battery post should not make any differance?..Clean or dirty.
....Caper...........
Old Sep 25, 2009 | 02:55 PM
Sorry for not posting make and model,but anyway it's a 2007 Sportsman 450,less than 40 operating hours,bought in January 2009 off dealers floor for a decent price.Since I am in town today gonna chance it and pick up a new thermosensor.
Old Sep 25, 2009 | 03:57 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you might have the dealer run your vin# to see if it was part of the recall for a bad ecm. like caper my 06' sp 450(like yours) was recalled as well but i had already sold it. it sounds like a bad ecm.
