Polaris Scrambler
Old Sep 24, 2009 | 07:49 PM
Justrunit's Avatar
Default Polaris Scrambler
Just picked up a 1998 500 scrambler this afternoon, need help it has no power would not even go up a little bank in back yard belt don't seem to be slipping please help good with hot rods but not atv's
Old Sep 24, 2009 | 09:20 PM
ftwflh's Avatar
Check the ramp buttons in the secondary clutch
Old Sep 24, 2009 | 09:33 PM
Justrunit's Avatar
It won't run but about 30 MPH, Can you explain please??
Old Sep 24, 2009 | 09:36 PM
ftwflh's Avatar
not shifting out right
Old Sep 24, 2009 | 10:19 PM
carlobee's Avatar
probably this. have you tried it out again?
Old Sep 24, 2009 | 10:29 PM
dirtjunkie's Avatar
+1 I would verify the clutch first, before looking at others possible issues
Old Sep 25, 2009 | 02:29 PM
Justrunit's Avatar
Thanks guys found the problem bad gas bad plug and and bad diapham in carb fixed running great now how can i get the most power out of it and how big of a tire will it take ( mud tires we have a honda 350 with 2 inch lift and 28 vampires they will go in the mudd great)
Old Sep 27, 2009 | 03:03 PM
ftwflh's Avatar
Not a good idea for bigger tires on a Scrambler.It can be done but you loose handling and loose topend due to the way it has to be clutched to compensate for the big tires.Pluss with no low range you will be smoking belts.
Old Sep 27, 2009 | 08:43 PM
Justrunit's Avatar
I was thinking like 26/25 swamp lites on alum wheels. What is the best muffler and clutch kit i could run the stock muffler was cracked we put a short glass pack on yesterday easy to install cheap is entirely way to loud.
scram5050
Aug 30, 2024 01:39 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 13, 2015 05:11 PM
