Exhaust Pipe
Old Sep 26, 2009 | 04:00 PM
Ragelite's Avatar
Default Exhaust Pipe
Ok so I was out today and crossed a swamp which Ive gone through a 100 times before and when i got out of the water and nailed the throttle it sounded like hell and wasn't feeling right, so I stopped and pulled the plastics off the side and noticed that the exhaust pipe was cracked all the way around the pipe was in 2 sections. Anyone out there have luck welding this stuff back together? I really dont wish to pay $100 for a new pipe.
Thanks
Old Sep 26, 2009 | 04:12 PM
700 sportsman's Avatar
Well, all the fix jobs i've heard of work for a while, but then they crack again, so take that for what it is
What bike do you have?
Old Sep 26, 2009 | 05:22 PM
Ragelite's Avatar
04 Sportsman 600 twin
Old Sep 27, 2009 | 02:16 PM
Ragelite's Avatar
So no one out there has ever welded a cracked exhaust before?
Old Sep 27, 2009 | 04:53 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
(Welding 101) Depends on where the break is. Welding on thin wall exuast pipe is a little tricky for the inexperianced but can be done. You have to be careful not to overheat the pipe or burn threw. My suggestion is to find a piece of pipe slightly larger about 1-2 inches long that will just slip over the existing pipe . Slip it on before you tack the break. Once tacked slide the new section over the break 50/50 if possible. Then tack all the way around at both ends. This method will be stronger than just welding the crack. So the answer to your question is yes, but if your unsure about doing it yourself then don't! Take it to skilled welder. A weld that has been burned in correctly will actually be stronger than the steel around it, but incorrectly will weaken the steel and most likley break again. Also you might be able to find a muffler shop that could fab up a whole new pipe or do the welding for you.
Old Sep 29, 2009 | 06:47 PM
helmethair78's Avatar
Buy a new pipe for an 800.
Old Sep 29, 2009 | 07:22 PM
Ragelite's Avatar
ok so the pipe is welded back together and seems to be holding fine so far. And yes if it cracks again Ill be buying a 800 head pipe!
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
