K&N air filter
Old Sep 26, 2009 | 11:25 PM
blzrnut's Avatar
Question K&N air filter
I recently picked up a 2000 Polaris Magnum 500. Will a K&N make any real difference ? I have had 3 prior machines. I ran K&N in all of them. I'm thinking that with the 500's weight a K&N won't make much difference, but I'm looking for someone that has done this to a Magnum 500.
Old Sep 27, 2009 | 06:46 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Here is the big difference, and you all ready know, the cost approach. You save on buying the paper Poo filter, and it is plugged up, vs the K&N, is just wash and re-oil and go.
Old Sep 27, 2009 | 09:26 AM
hurly's Avatar
def worth it.......just put one on my 700 twin. I noticed the increase instantly.
Old Sep 27, 2009 | 01:50 PM
RticKwad's Avatar
Runs Stealth!
Remember not to OVER OIL it! I did that and it will run rich and higher RPM's. Then I needed to re-clean, dry and lightly spray even small amounts. Over all, I think its a great add, recommend using the pre-filter with it!
Regards,
R'
Old Sep 27, 2009 | 06:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
imo there wouldnt be much if any differnce just replacing the air filter. yes it will breath better but more in needs to have more air out to make a differnce. imo
Old Sep 27, 2009 | 08:19 PM
hoytultratec's Avatar
if your riding real dusty conditions I would go with a UNI anyday K&N let dust in and its not like your gonna gain performance from it.
Old Sep 27, 2009 | 08:26 PM
HARLEY_OWNER's Avatar
i have a k&n filter.. with 3 n 1/2 inch intake bigger jets and hopped up the timing..
i see a diffrence....
Old Sep 27, 2009 | 09:30 PM
i put one on my 400 2 stroker, after a weekend ride up in langlade county im glad that pre filter was on my airbox 200 miles and the thing was very dirty, i guess what scares me is when you look at a k&n you can see light through it on the low side of the filter cant believe dust will not get through it? the filter deffinatly helped lean my machine out a bit but i didnt notice anything performace wise its already fast. UNI all the way for me .
Old Sep 28, 2009 | 12:02 AM
chuck_raduenz's Avatar
i have a k/n on mine. i dont notice any differance in power or more speed and what not. the only real reason i got it was so i could clean it rather than toss and buy new. i paid $40 for the filter. i reused the pre-filter. so far iv cleaned it once. the recharge kit was $12. but i figure i can clean my filter 2 or 3 times a yr and the it should last me a long time. so over all ill be saveing money. i still have the oem paper filter just in case......
Old Sep 28, 2009 | 04:05 PM
where are you from? i live in clintonville and go camping on my uncles land in white lake... over labor day we rode all the way up to parish from white lake
