03 400ex not starting
Old Oct 2, 2009 | 07:58 AM
mechanicock's Avatar
Default 03 400ex not starting
I recently moved and ive had to keep my 400 outside, I have a cover on it. Yesterday went to crank it up and it simply wouldnt turn over I was pressing the starter so much i almost killed the battery. Could it be that the gas is bad? I really dont know, if anyone has some insight that be great.
Thanks,
Old Oct 2, 2009 | 10:35 AM
budedm's Avatar
Yes, gas is bad. You may have to take the carb off and apart and clean it with carb cleaner. Then drain all the gas out of the tank. Then put fresh in antry again. And DON'T crank the starter that much. It's not the battery you should be concerned about - It's the STARTER. You'll fry it. If it doesn't start in a few seconds, there's a problem.
Old Oct 2, 2009 | 08:59 PM
thanks thats what i thought, im gonna drain the gas tomorrow and see what gives.
thanks again
DTroyer01
Jul 3, 2015 07:34 AM
Bm400ex
Jun 22, 2015 09:16 AM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
jbertch
Nov 6, 1999 07:07 PM
