Bombardier 500 Electric Shift Prob. Bleed?
Old Oct 9, 2009 | 09:35 AM
eagleone's Avatar
Default Bombardier 500 Electric Shift Prob. Bleed?
I changed a Sparg Bearing, had starter problems. Had to do it with enghine out of chassis. Put it back in, now I have no electric shift up or down. Dash Lights all work at start up. ISeems to be in 2nd gear, have forward, reverse, and hi-lo ranges. Do I have to bleed the clutch?
worked great before. Also looking at connectors & connections. Any ideas? Where is the bleed **** on 2000 Rotex Traxter 500 CC
Old Apr 5, 2010 | 09:47 AM
cal757's Avatar
Default I am having the same problem with my Traxter
Did you figure it out? If so, what was the remedy? Thanks!
Darrell
Old Apr 2, 2011 | 07:14 PM
pegleg20011's Avatar
Smile 2000 traxster shifting problem
I have just had the same problem took engine out replaced sprag clutch. now shifter is not working . I purchased a service manual and it says you have to have the STPS(sub transmission position sensor) and the GBPS(gear box position sensor) recalibrated.you can buy a jumper for self diagnosis from your dealer only 10.00 bucks
Nosniborpapa
Sep 19, 2015 07:07 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
lancemll88
Sep 6, 2015 03:03 AM
