03 DS650 Baja- No spark
Hi everyone- I have a tough one- quad has no spark, checked all fuses - all are good, have been ohming out all of the wires- appear good, kill switch ok- clutch switch ok, has a new pick up trigger coil- old one wasnt producing a signal, now it is and is per spec per manual( which the wiring schematics leave a little to be desired). Engine cranks like a champ= new battery, bike has a ron woods stage 2 kit on it with race ecu- I changed the ecu with one from ebay (pro for,- protech) something like that- would plug in either direction to hardshell- I dont recommend purchasing this product- still no change, no spark, Just picked up quad from local dealer- they scratched theyre heads too- told me they tried a new oem module- and surprise- still no spark, so after it spent a month there I just got it back, im not sure they even installed a module as I felt my BS meter pinging. Any ideas would be great???
thanks-
thanks-
Did you install the trigger pick up or did the shop install it . there needs to be .020 gap from trigger pick up and the pick up on magieto. you have to bend the tab to adjust,dont just bolt it on. just a thought. also did the bike just quit or did you by it not running.
I installed the trigger pickup assy, and set the air gap- and then I verified with my fluke 88 meter it was generating the proper signal. I purchased the quad in non running condition. I will keep working on it as time allows, thanks for your input.
mc
mc
thanks-
thanks-
LOL We more than enough Honda and Yamaha bikes over here but unfortunately Im the only guy with Bombardier
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
