'97 fourtrax 300
Old Oct 19, 2009 | 09:49 PM
Spougo's Avatar
Default '97 fourtrax 300
My starter switch does not work. Starter turns if solenoid is jumped. Spark plug will not fire either. Checked all switches, fuses and cleaned all connections. The switch and run/off switch along with the ignition switch tested good. I feel as if i am running out of options. Can someone help me out?
Old Oct 21, 2009 | 04:21 PM
Gimpster's Avatar
Make sure your neutral light is on. The unit will turn not over with the starter button or not fire unless the CDI sees neutral.
If the neutral light switch is bad, it van be grounded out, green wire with a red stripe.
The switch (sender) is under the small tin engine cover just inside the right footrest on the lower side of the engine.
Hope this helps ya
~ Gimpster ~
Old Oct 21, 2009 | 05:06 PM
Spougo's Avatar
I will give it a shot. Can't thank you enough.
Old Oct 22, 2009 | 03:59 PM
Gimpster's Avatar
By the way, I was fat finger typing in my first reply, the word van should have been can
~ Gimpster ~
Old Oct 22, 2009 | 10:22 PM
Spougo's Avatar
That did it. Thank you for your help. It is very much appreciated!
Old Oct 31, 2009 | 06:27 PM
bigowens's Avatar
Default 2001 350 4x4
hey i have the same problem with my bike it wont start with electric start and the netural light wont come on what can i do
Old Nov 6, 2009 | 09:23 PM
Spougo's Avatar
I just bought a new switch from honda and that fixed it for me.
Old Nov 7, 2009 | 07:44 AM
bigowens's Avatar
how much do they run for and are they hard to insatll
Old Nov 17, 2009 | 04:46 PM
Spougo's Avatar
I bought a neutral and reverse switch and they were about $50 for both (neutral and reverse switch). They are down on the lower right side of the crankcase and a 14mm socket changed out mine. Not to difficult at all. I dont know if i had too or not but i jacked up the right side of the wheeler so no oil would spill out, if it does.
Old Nov 18, 2009 | 06:44 AM
bigowens's Avatar
ok well it should be close to the same thing for my 2001 350 eh or at least similiar i hope
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
Steeldon
Sep 8, 2015 10:51 AM
ScopeZ_
Jul 28, 2015 01:44 AM
