stripped carb screw....
Old Oct 20, 2009 | 01:04 AM
jetlag's Avatar
Default SE Valve nut/ choke cable
I originally made a post about a stripped nut but figured it out and decided to edit this thread and make it something else..haha. If a moderator could change the title for me, I'd greatly appreciate it
Ok, so I am in the middle of removing my carb.
Looking at the service manual makes no sense at all!
It says "Disconnect the choke cable by turning the SE valve nut, being careful not to damage the SE valve"
Well, I turn the valve nut and nothing happens other than it wanting to come out of the carb.......
Old Oct 20, 2009 | 03:35 AM
JeffinTD's Avatar
What machine are you working on?
Generally you unthread that nut, and withdraw the SE valve from the carb. It will probably be a cylinder shaped thing, with a pin protruding on the end, and a seal somewhere on the side of the cylinder.
Old Oct 20, 2009 | 03:49 AM
jetlag's Avatar
2001 Rancher 350
I unthreaded the plastic nut all the way out but it won't pull out.
Old Oct 20, 2009 | 04:37 AM
HondaMechanic's Avatar
It won't pull out because the choke plunger is seized ..
Old Oct 20, 2009 | 05:57 AM
JeffinTD's Avatar
You might try some penetrating oil and letting it soak.
Old Oct 20, 2009 | 03:23 PM
jetlag's Avatar
So how should I get it out? Just pull on it really hard and then replace the cable and plastic nut? Or can I buy a bolt to plug the hole in the carb? I've never had to use the choke.
Old Oct 20, 2009 | 03:55 PM
JeffinTD's Avatar
I'd be as gentile with it as possible. After soaking with PB Blaster or whatever, try giggling it around.
Hopefully it will come out and you can clean it up and reinstall. You don't want to plug the hole with something else, as that would leave the choke circuit on.
Old Oct 20, 2009 | 04:01 PM
jetlag's Avatar
Oh, well that's no good... How do I get the plastic nut assembly off the choke cable? Or is that what you are saying is seized up?
On #9, it is 3 pieces?
Old Oct 20, 2009 | 04:22 PM
jetlag's Avatar
What if I cut the cable and leave the end in the carb? Would that work as a temporary fix?
Old Oct 20, 2009 | 05:41 PM
Don't cut the cable .. I would just give the cable a good pull , chances are it will pop out of the 2 ears of the plunger ..
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
