Part Identification Help
Old Oct 22, 2009 | 08:04 PM
onasport400's Avatar
Exclamation Part Identification Help
Hello I was wondering if anybody knows what this part is and where it goes:
This is on a Polaris Sport 400L.
Thanks, Jimmy
Old Oct 22, 2009 | 08:07 PM
one way drain/overflow tube that goes to float bowl.
Old Oct 22, 2009 | 08:28 PM
And comes from where?
Old Oct 23, 2009 | 05:17 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
comes from the carb.
Old Oct 23, 2009 | 10:55 AM
Isn't the float bowl part of the carb?
Old Oct 23, 2009 | 11:05 AM
02magnum500's Avatar
Gets his share of deer.
Yes, should go on the nipple on the bottom of the float bowl as an overflow vent line.
Old Oct 23, 2009 | 11:12 AM
Thank you, that's what I was looking for!
Old Oct 23, 2009 | 11:13 AM
I use some superglue to hold the tube in place on the nipple.
Old Oct 23, 2009 | 11:15 AM
OK. And does the other end just hang?
Old Oct 23, 2009 | 11:20 AM
Yep, run the other end through along side the engine and down below the frame (should hang down when you look under your ATV), this just gets the drip or 2 of gas off your frame. then the gas will drip on the ground not your ATV.
