DynoJet jet kit, HMF pipe, K&N
Old Oct 23, 2009 | 01:13 AM
jetlag's Avatar
Default DynoJet jet kit, HMF pipe, K&N
I recently installed an HMF pipe and dynojet kit. My Rancher already had a K&N filter on it.
I installed the jet and needle groove recommended by the instructions.
Everything is fine WOT but sometimes under partial throttle the atv will sputter a little bit.
It has a 124 main jet, needle on 3rd groove, and the mixture screw was fully seated then turned back out exactly 3.5 turns.
Any ideas?
Old Oct 23, 2009 | 08:31 AM
Patton228's Avatar
Try adjusting the mixture screw can be a lil different due to certain circumstances.
Old Oct 27, 2009 | 01:15 AM
Daughtrylc's Avatar
Go to the next size up jet.
Old Oct 27, 2009 | 03:51 AM
jetlag's Avatar
But I thought the main jet mainly helped Wide Open Throttle?
Would changing the needle or "pilot" jet help for my low end problem?
Old Oct 27, 2009 | 04:12 AM
Daughtrylc's Avatar
Good point, after reading your post again, Im thinking it my be your air\mix. try 2.5 turns instead of 3.5. Also make sure you know your attitude? Google it to be sure
Old Oct 27, 2009 | 02:46 PM
jetlag's Avatar
I'll try the screw.
Memphis alt. says 331ft above sea level, so I had that set right at <3000.
Old Oct 27, 2009 | 06:56 PM
Daughtrylc's Avatar
Call Dynajet tech line. They were very helpful, even called me back!!
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
