Why would my speedometer bug out like this?
Old Oct 24, 2009 | 05:44 PM
Angel of Death's Avatar
Default Why would my speedometer bug out like this?
Machine is an '04 Sp700 carb'd and the only changes I made before the speedo decided to bug out is unplugging the fan to wire in a on/off switch because the fan would not turn on by itself.
Keep in mind for the entirety of this video, the machine is standing still.
You can watch it be totally wacky here:
YouTube - 2004 Polaris Sportsman 700 Speedo
Old Oct 24, 2009 | 09:53 PM
TLC's Avatar
TLC
Maybe dirty Hall Effect sensor,Part number #27. I say dirty because usally when they go your speedo does not come back to life. If your AWD still works but speedo does not then the speedo is good but its wheel sensor(Hall Effect senor $45) is bad .
Old Oct 25, 2009 | 05:58 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
looks almost like the tac working instead of the speedo. did you unhook the switch you installed and try it again to see if it worked normal? if it does work then you know you got some wrong wires some where you tapped into. just a thought
Old Oct 26, 2009 | 05:46 AM
A wheel speed sensor does make sense, I'm gonna check that out this week. Thank you very much!
rawbdiggity
Sep 7, 2015 12:05 PM
byronman
Sep 6, 2015 06:34 PM
400H0
10
Aug 20, 2015 07:34 PM
chuck1177
Jun 30, 2015 09:52 AM
nevermiss
Apr 1, 2000 10:53 AM
