Valve adjustments on Polaris ATV's?
Do valve adjustments need to be made periodically on Polaris ATV's? Mine has a slight clackity sound coming from it at idle. I was just wondering if valve adjustments were normal for these machines.
yes they do need valve adjustment at certain hour/milage. not sure on your bike what the time frame is. it should say in your owners manual or maybe someone here will know how often. worse case, call a dealer to get the correct info.
Not sure on the new 850 but all the older twins IE 600,700,800 were hydraulic valves therefore not needing valve adjustments! I am sure it is the same on the new 850.This is one feature I do miss on my Popo tho not that bad to do on the Grizz.
