2007 sportsman 700 efi mods
Ok. Whats the scoop on mods for this? Most posts are getting to be a couple years old. I'm wondering what works. I have a k&n air filter, and Polaris / white bros muffler. Should I do the 800 header? fuel programmer? 800 primary clutch? or clutch kit? Timing key? What works? I dont mud ride. I ride mostly mid to high speed trails. I still want dependability but I just a bit more mid range snap....
by the sounds, you have already done the homework on what people are doing. back awhile ago the big thing was to put the air intake and header pipe on of the 800 becuase it breathed better and some noticed the power differnce. imo
I installed the 800 crank, balancer, 800 HO cam, JE hi comp pistons and had V&H do the head. With a LeoVince full system and Power Commander it was a 20% increase as measured on a Dynojet dyno. Also has EPI clutch kit. I raced a XP850 and up to 70mph he only had me a bit over a length so I was happy with that!
I bought the quad used for $2000 and on the first ride got smoked by a 800X2. Luckily I am in the industry and get all my parts for cost, V&H comped me the headwork so out of pocket was like a grand. Now I leave the X2 for dead!!!
It was measured on a Dynojet chassis dyno, so yes, at the rear wheels. Unfortunately dyno numbers are somewhat irrelevant with a CVT style clutch which is why I stated % of increase. If you use the same tires and same clutching from one day to another you are fine but to compare two different machines doesn't tell you a whole lot.
