2002 TRX350FE Clutch Slipping 3rd Gear & Up
Old Oct 29, 2009 | 10:38 PM
k5beason@gmail.com's Avatar
Default 2002 TRX350FE Clutch Slipping 3rd Gear & Up
I have a TRX350FE with a new clutch that slips when cold from 3rd gear to 5th. It slips in the first two gears but not terribly bad or noticeable. The slippage occurs mostly when cold and subsides as the ATV warms up. The best way to describe the sensation is that of a CVT as it slowly accels/grabs and when throttle is reduced it grabs (harder) than with throttle applied. Originally used Valvoline 10w40 for about 15minutes and thought it was possibly the oil so I changed it out to Honda gn4 10w40. I have a repair manual and have adjusted the clutch adjustment nut/screw per the Honda Manual which seemed to have little effect no matter what the adjustment but is set 1/4 back from first felt resistance currently. ATV shifts in and out of gear fine, idles without movement but slips which becomes readily apparent in the higher gears. I have an identical atv and even when the problem atv warms up it doesn't grab nearly as hard as the other rancher. Any Ideas what to check next??
Old Oct 30, 2009 | 12:13 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Clutch packs are disposable items that need to be replaced now and then. Probably just worn out after 8 long years.
Old Oct 30, 2009 | 04:41 AM
HondaMechanic's Avatar
The clutch cover will have to be taken off and the clutches checked .. The manual clutch will have to have the plates & disks & springs measured , and the centrifugal clutch drum checked for wear and check if it's burnt ..
Myself it sounds more like the centrifugal clutch ..
Old Oct 30, 2009 | 05:20 PM
Default Again Clutches and Motor are brand new ATV
The two clutches and motor are brand new... is it possible for one of them to be bad from the start?
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
