2001 350 honda foutrax
Old Nov 1, 2009 | 06:11 AM
bigowens's Avatar
Default 2001 350 honda foutrax
Hey there i was wondering if someone could help me bike wont start at all wont rool over with electric start neutral light not on will rool over if soilonoeid crossed desperatley need help on what this is and how i can fix it
Old Nov 1, 2009 | 06:46 AM
HondaMechanic's Avatar
You will have to check the gear position switch ... Honda had trouble with 2000-01 TRX350 shift drum breaking at the gear position switch drive side , causing the gear position switch not to show the gears (proper gears) including not showing neutral ..
Here is the tests for the gear position switch ..
Old Nov 1, 2009 | 07:09 AM
bigowens's Avatar
so if the neutral has no continuity what does it mean what do i have to do?
Old Nov 1, 2009 | 09:50 AM
If it is a TE/FE model then do the rest of the gears show on the dash or of it is a TM/FM model does the reverse indicator show when in reverse ..?
Old Nov 1, 2009 | 10:13 AM
bigowens's Avatar
reverse does not show on dash when its in reverse
Hunter100us
Oct 7, 2015 11:46 PM
bigred20653
Aug 31, 2015 12:41 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Aug 5, 2015 02:10 AM
maxjung
Jul 14, 2015 03:10 AM
