Tool Kit recommendations?
Putting together a trail tool kit for my '09 Sportsman 500 EFI X2. For starters, I need to know if Polaris machines are 100% metric or not, and would appreciate some specific recommendations on wrench sizes to "not be caught without". I have the usual stuff under control (Warn winch kit, tire repair, electrical repair bits & pieces, tie wraps, star wrenches, multi-tip screwdriver, spare belt, etc.), plus a set of 3/8" metric sockets and a Leatherman. But I'm thinking it's a good idea to also carry a few box/open end wrenches to fill out the possibilities. Would 8, 10, 12, 14mm be sufficient, or do I need to also carry 17/19mm? I'd like to be able to bail myself out up to and including changing the clutch belt on this thing if necessary.
Thanks!
Jerry
Thanks!
Jerry
well my stock tool kit (bag) came with 2 wrenches, one standard and one metric, with different sizes on each end, but I can't remember what sizes they were, but I know one was 1/2" and we had to use that for an emergency operation the other day (don't ask)
I can check the sizes if your X2 didn't come with a tool kit
The 09's should be all metric. I bought one of the small crafstman tool kits that has a bunch of sockets, ratchet, adapter, extension, and multiple screw bits. The other half of the plastic box has storage w/ a cover and I put channel locks, pliers, and needle nose. Fits nicely with the rest of my stuff in the rear lock-n-ride box.
A set of standard sockets/wrenches for sure. Flashlight,tire pump(I've got a very small hand held $8.00 at wal-mart slow but effective),Rags,first aid kit for booboo's,small container with assorted screws,nut and bolts.
I have a basic metric/SAE socket set, Needle nose pliers, knife, rag, funnel, a small amount of clear plastic tubing (to transfer fuel), tire plugs, and tin snips (I got caught in bailing wire around the tire once).
Thanks,
Jim
Thanks,
Jim
I felt motivated to search for this thread because I think these are good threads and we all discover a wealth of informtion.
Ref: http://forums.atvconnection.com/pola...ols-carry.html
Ref: http://forums.atvconnection.com/pola...eak-downs.html
Ref: http://forums.atvconnection.com/pola...you-carry.html
Ref: http://forums.atvconnection.com/pola...ut-riding.html
Cheers,
R'
Cheers,
R'
Great post, Rtickwad... I printed the four threads, will work my way through them with a pencil and create a list of the stuff most applicable to my area and the way my wife and I ride. I found several YouTube videos on how to change a belt, BTW. Very informative.
Seems like there should be some sort of sticky post for this subject. I'll bet there's also a market for a self-published little book/booklet on this subject. I know I'd have been happy to buy one if it existed!
Thanks to all for the good inputs..
Jerry
Jerry
Don't forget the trusty old crescent wrench. A small one will work nicely if you get caught without that certain size metric or standard wrench... (always seems to happen at the wost times)
