Tool Kit recommendations?
Old Nov 2, 2009 | 02:26 PM
tw1st3d1's Avatar
flash light, lighter, electrical tape (or duct tape) water if water cooled engine, stick of JB Weld, or some type of two part epoxy.
Old Nov 2, 2009 | 11:38 PM
RticKwad's Avatar
Runs Stealth!
Your welcome PICKER77, I still remember the Bob Villa show intro that ole Bob could work a allen wrench in 18 different ways. I really like to know the whole 18, lol
Terb, what is the JB weld stick for?
Thx,
R'
Old Nov 3, 2009 | 10:16 AM
Mic_'s Avatar
Originally Posted by picker77
Putting together a trail tool kit for my '09 Sportsman 500 EFI X2. For starters, I need to know if Polaris machines are 100% metric or not, and would appreciate some specific recommendations on wrench sizes to "not be caught without". I have the usual stuff under control (Warn winch kit, tire repair, electrical repair bits & pieces, tie wraps, star wrenches, multi-tip screwdriver, spare belt, etc.), plus a set of 3/8" metric sockets and a Leatherman. But I'm thinking it's a good idea to also carry a few box/open end wrenches to fill out the possibilities. Would 8, 10, 12, 14mm be sufficient, or do I need to also carry 17/19mm? I'd like to be able to bail myself out up to and including changing the clutch belt on this thing if necessary.
Thanks!
Jerry
Do not forget duct tape!
Old Nov 3, 2009 | 11:12 AM
gaspumpcity's Avatar
On any weekend the jb weld will help out on most clean plastic if you have time to let it dry! J-B Weld Company - J-B STIK Product Information
Old Nov 4, 2009 | 07:46 AM
  #15
WheelinSyr's Avatar
Snap ring pliers. Rarely needed but hard to substitute when you do.
Old Nov 4, 2009 | 09:02 AM
  #16
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Spare RAD to change out when the first one gets plugged!..LOL
Or 12 volt trail-side water pump.....Comes in handy if you have room........Caper..............
Old Nov 4, 2009 | 09:04 AM
  #17
RticKwad's Avatar
Runs Stealth!
I Second the motion for the STICKY! (Hey Stendori can you make it happen?)
See we all learn something here, I didn't even know about the JB Weld. I could use some on my footwell tear and for Nephews Honda plastic tear. What color does it end up to be, more like a primer color?
Also, another note: QUAD ATV Magazine has excellent repair articles, sometime I buy it just for that.
Cheers,
R'
Old Nov 4, 2009 | 10:47 AM
  #18
Carrying the correct tools for the job that you are going to do in the field require hand on experience such as belt change.Find some spare time and do this at home then you will know what correct tools to carry. Practice make prefect sense. I also have a small cheap volt ohm meter from radio shack that I have used to help out others in need.
wendal
Sep 7, 2019 06:46 AM
bigred20653
Oct 2, 2015 10:05 AM
kampswas
Sep 23, 2015 05:05 AM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
Brandon400
Sep 5, 2015 08:44 PM
