Going to construct a set of ramps any idea of a design for ramp's?
For loading the quad with. I don't feel like spending over a 100 dollar's for a pile of metal that cost's less than 20 bucks. I can probally weld a set together in less than a half hour. I plan on building a set 12"x1.5"x8" made out of 1/8" angle iron.
I know Dennis kirk has aluminum angle irons for around 8-14 dollars, and you supply either a 2x8 or 2x12, or they will sell you the kit for 42 dollars. It's light weight and durable. If you think you need traction on the ramps, just cut up an old tire so you have two narrow strips of rubber on each ramp for traction
If you have the time stop by your local scrap metal dealer. I managed to pick up a 16ftx12"x1.5" piece of perforated catwalk material. Its galvanized ( so it wont rust) and the perforations on the face of the catwalk TOTALLY eliminates any chance of slippin off even when things are iced up. The best part was i got the piece for FREE, all i had to do was cut it into 2 8ft pieces :-] The ramps are indestructable ! ( i have seen those lightweight amuminum ramps collapse while loading an atv so if i were you i would shy away from aluminum ramps )
