97 sportsman 400 got fuel &spark wont start
just got a 97 sportsman 400. got fuel got spark, turns over fine with electric starter but will not start. I read a thread about a pulse coil located behind the recoil.....? this thing still looks brand new with a 1000 miles on it. how can you have spark and fuel with no fire...? any suggestions???
so far ive only checked fuel and spark. I did NOT ground the plug when I ckecked for spark. I'll do it today. I'll also repace the plug with a new one for the hell of it. Polaris dealer is right around the corner. I'm planing to stop by for some info.... I hope. One guy said some thing about a coil and said it wouldnt fire with the electric start but it should fire from using the pull start. Idont know my pull starts been taken apart maybe this will help someone else.
I got it fellas. Icant believe it... I'm almost embarrased. Lesson learned, Even if a spark plug sparks it DOES NOT mean its good. Replaced it with a new NGK BR8ES gapped to 28 thousands. It fired right up. FYI Polaris tech says compression should be 90-95lbs psi.
and if that 400 is a 4 stroke then i cant remember the numbers off the top of my head.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
Stan928
Jun 15, 2015 03:12 PM
