2001 Polaris 90 hard to start when cold
2001 Polaris 90 is hard to start when cold. Will start / run fine when warmed up. I can't find fuses, it has some type of plunger mechanisim on carb. Carb is clean and machine runs fine when hot.
Where are fuses?.
Is there a choke, How does it work?.
Where can I get tech manual?.
Thanks to all.
Where are fuses?.
Thanks to all.
It has an elec choke(doesn't work well),just hold your thumb over the air box tube inlet blocking air flow,will start up a lot faster!! Common problem with the older 2 strokes. OPT
Thanks OPT.
skittero
35
Mar 1, 2019 12:39 AM
Big600twin
14
Jun 16, 2015 09:30 AM
