trailboss 325 trouble starting
Old Nov 25, 2009 | 07:50 PM
roofdogbill's Avatar
Default trailboss 325 trouble starting
my sons 325`s problem is when we try to start it,it seams like the starter bendix does not catch the flywheel long enough for it to kick over,anybody know what the fix would be for this,thanks in advance for any help.
Old Nov 26, 2009 | 02:03 AM
Remove recoil cover and check teeth on starter bendix,if sharp and worn could cause "kickback" not staying engaged with flywheel,could just need to be replaced. Also if spring is stretched and worn or bendix is dry(needs grease at frontcup and shaft) can cause sticking.
Old Nov 26, 2009 | 05:09 AM
thanks,i put new flywheel in and still had problem,guess i will order bendix and give that a try.
Old Nov 26, 2009 | 07:00 AM
Kerbbirds's Avatar
Make sure the battery is good, if battery gets weak it will cause these symptoms.
Old Nov 26, 2009 | 09:41 AM
it has done it with a new battery and and a fully charged older battery.
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
1000gade
May 27, 2015 12:37 PM
Michael2
May 6, 2001 01:07 PM
sethb
Aug 5, 2000 11:46 AM
atving
Nov 17, 1999 09:24 PM
