1985 Honda 110 - No Spark!
Hello,
I just aquired a decent 1985 Honda 110 ATV for $100.00. The machine was sitting for a fairly long time and all three tires are dry rotted.
Anyway, the machine has no spark and I'm not sure where to start looking for the issue.
Can anyone give me some advice as to what to check for on these machines? There is a CDI box on the side of the engine, and when I pulled the cover off, the components appeared to be in good shape.
Thank you for your suggestions.
check the spark plug first. as there known to go though plugs. on my 185s i had to replace plugs on it a few times a yr. just to start with. if that dont work go here for a wire diagram. make shure all is good on that end. then start checking wires. http://www.files.3wheelerworld.com/Wiring/ATC110x85.jpg
CRamshaw777
Jul 18, 2015 05:46 PM
