2001 400 Sportsman steam out of radiator cap
Old Nov 26, 2009 | 04:41 PM
ftwflh's Avatar
Default 2001 400 Sportsman steam out of radiator cap
I have steam coming around the cap.Why would it be doing this?
Just set the valves replaced overflow hose.Now it is blowing steam.
Any ideas?
Old Nov 26, 2009 | 05:46 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
no overheating issues from air in the system? is the cover holding pressure as well?
Old Nov 26, 2009 | 07:30 PM
ftwflh's Avatar
It is fillingthe over flow up too
Old Nov 27, 2009 | 06:32 AM
ZAKAZIM's Avatar
So What I think Stendori is saying is check the rad cap. I had this same thing going on with a 500 i had and I found that the cap was bad. P/U a new cap at a Napa store and try it. I think it was like $10.00. Run the unit one compleate heat cycle to remove any air and put the new cap on. IMO this will fix it
Old Nov 27, 2009 | 06:33 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
what happens if you left the rad. cap on the first notch and don't tighten it all the way(so it can't build pressure) to see if it still going to do it? does it fill up ovrflow beofre it gets up to temp?
Old Nov 27, 2009 | 07:08 AM
Kerbbirds's Avatar
If its not a bad cap and is still pressurising radiator its probably a bad head gasket.
Old Nov 27, 2009 | 08:01 AM
TLC's Avatar
TLC
Maybe a air lock and your system needs a burp. A good sign of this is the top rad hose is hot and the cap may steam but the bottom rad hose is still cold.
Old Nov 27, 2009 | 08:20 AM
ftwflh's Avatar
I am going to go to the Polaris shop today and ask him what he thinks.And see if he has a old cap to try.I am betting the head gasket is bad.
I will let you guys know later.This has me stumped
Old Nov 27, 2009 | 12:47 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if it's building pressure and not over heating and psuhing steam then i agree a bad head gasket is posiable for sure. good luck and let us know.
Old Nov 27, 2009 | 02:05 PM
ftwflh's Avatar
Wink
Took it to get the system pres checked had to put on a cap neck(old one was disformed )
System held pres. but with cap off it would push fluid out the cap and into resevoir.Bob (Polaris shop owner) wants me to check water pump impeller first then go to head gasket.
It is good being friends with a shop owner
Cole Hadden
Jun 15, 2025 09:05 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Hunter100us
Oct 7, 2015 11:46 PM
ltrmc02
Jul 22, 2015 04:50 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
