Bayou 185 bog at 1/2 to full throttle
Old Nov 28, 2009 | 08:50 PM
artjtrout's Avatar
Default Bayou 185 bog at 1/2 to full throttle
Me again, so I got the head reinstalled (thanks for the torque and lash settings Williebee). It starts good, idles good... great acceleration from stop to 1/2 throttle, then it bogs bad.... I can nurse it up to 3/4 throttle but nothing but bog after that along with a small intermittent backfire through the exhaust. The main needle is at 1/2 on the adjustment slots (and there are 2 small plastic washers there.) Too rich? I didn't want to move to the top setting and take out the washers for fear of running to lean and over heating it. Any ideas?
Old Nov 28, 2009 | 09:07 PM
0010's Avatar
That sounds too rich to me. Especially the backfire bit.
Old Nov 28, 2009 | 09:40 PM
artjtrout's Avatar
Ok, I leaned it up to the top but same results. Could I be off a tooth on the valve timing? It revs great with no load.
Old Nov 28, 2009 | 10:36 PM
offroad_patrol's Avatar
If it is carbureted I would check the fast jet in the carb to see if it is clogged, that is an easy fix and thats where I would start. That certainly would explain the symtoms you are having....
Regards,
Max
Old Nov 28, 2009 | 10:50 PM
artjtrout's Avatar
Even though I had cleaned the carb a few days ago before the head gasket replacement, I will do that again tomorrow to make sure that ain't it... Thanks for the suggestion!
Old Nov 29, 2009 | 02:45 AM
Maybe you'll find the problem, keep us posted I'd be interested to hear what you find...
Max,
Old Nov 29, 2009 | 05:05 PM
artjtrout's Avatar
It's not the cam timing, I swapped the carb from my other ATV and was able to run wide open.
Not sure if it's the original carb though. After the swap and first few runs, I noticed that the fuel pump wasn't making any noise and then it started to not run. When I took the fuel pump off there was gas in the upper end of it. What I'm thinkin is there is a leak in the pump diaphram and gas is getting to the top and then the pump fails to pump. It also leaks from the top so a new pump is in order anyway .
I checked some online parts places and the want 140$ for a replacement, Ouch. I checked at Advance Auto and they have an aftermarket pump from Mr Gasket that runs 44$, and puts out 2-3.5 lbs pressure. There is also a Mikuni Pulse Fuel Pump that works off of crank case vacum for 20$. I could hook it to the existing crank case vent? Any thoughts? Is there a place I can get a re-build kit for the original pump? I only paid 650 for the pair of ATV's and need to get another battery and a muffler/spark arester still....anyone know where I can get a muffler/spark cheap?
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Polarisman1123
Sep 13, 2015 10:06 AM
blpersinger
Jul 15, 2015 09:56 PM
