07 800
My 07 800 is hard to shift when first starting up and with it on block's running with the belt cover off, when in gear and idling if you hit brake there is a light squeling or scraping noise coming from driven clutch. My idle is correct, but it seems to shift easier after about half hour of running. It is manageable but getting ready for winter riding and hatfield's and while I have it torn down I may as well fix it.
Thank's for any input
Thank's, I have already replaced the lower motor mount about 1000 mile's ago, bike has 1500 mile's, this one is still ok, How do I check the one way bushing?
Thank's for the help
you should be only able to turn the bsuhing one way and not the other if it's working right. try to see the fiber washers on the out sides of the bushing,hard to see, to see if there messed up. i mo
