07 800
Old Dec 3, 2009 | 05:30 PM
Outback31's Avatar
Has ridden Rockhouse and Bearwallow trails.
Default 07 800
My 07 800 is hard to shift when first starting up and with it on block's running with the belt cover off, when in gear and idling if you hit brake there is a light squeling or scraping noise coming from driven clutch. My idle is correct, but it seems to shift easier after about half hour of running. It is manageable but getting ready for winter riding and hatfield's and while I have it torn down I may as well fix it.
Thank's for any input
Old Dec 3, 2009 | 06:22 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check the one way bushing in the drive clutch.
Old Dec 3, 2009 | 07:05 PM
700 sportsman's Avatar
I'd also check out the motor mounts, they may be split, and causing the motor to shift slightly causing the clutches to be mis aligned, I've heard of several mounts splitting like that
Old Dec 3, 2009 | 08:41 PM
Outback31's Avatar
Default 07 800
Thank's, I have already replaced the lower motor mount about 1000 mile's ago, bike has 1500 mile's, this one is still ok, How do I check the one way bushing?
Thank's for the help
Old Dec 4, 2009 | 05:51 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you should be only able to turn the bsuhing one way and not the other if it's working right. try to see the fiber washers on the out sides of the bushing,hard to see, to see if there messed up. i mo
