Warn winch
Old Dec 13, 2009 | 06:13 PM
leopold22103's Avatar
Default Warn winch
Getting a new winch soon, what's the difference between the Warn RT25 and the RT30 besides ht RT25 has 8 ga. wire and the RT30 has 6 ga. wire???
Old Dec 13, 2009 | 06:16 PM
Mongrol's Avatar
"Official Site Skeptic"
500 lbs straight pulling capacity.
Old Dec 14, 2009 | 04:48 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the heavier the wire, the more power they can handle meaning stronger pulling. imo
Old Dec 14, 2009 | 09:06 AM
I think the RT30 is a 3000 lb. winch and the RT25 is a 2500 lb. winch. Probably a slightly stronger motor to go with the heavier wire.
Old Dec 14, 2009 | 05:45 PM
chuck_raduenz's Avatar
agreed as above/ rt30 is a 3000lbs pull and the rt25 is a 2500lb pull, along with the ga of power wire. rt also stands for rugged terrain. the xts come with synthetic rope. the rt come with steel cable.
Old Dec 14, 2009 | 08:41 PM
Witch one is better steel cable or synthetic???
Old Dec 14, 2009 | 10:01 PM
DODGE57HEMI's Avatar
Mopar Man!
Synthetic all the way! The only thing you have to watch with Syn is to not rub up against something while pulling such as trees or rocks other than that it is a pleasure to use and will do everything a cable will with half the weight and no sharp edges to cut your hands!
Old Dec 15, 2009 | 07:33 AM
mtpockets's Avatar
When you buy the RT25 or RT30 does it already come with the correct MOUNTING PLATE or is that an extra cost on top of the price of the winch?
Old Dec 15, 2009 | 07:48 AM
I'll have to buy the mounting plate separately.
Old Dec 15, 2009 | 08:37 AM
mtpockets's Avatar
How much $$ is it?
