'96 scrambler 400 rear brake issue
Old Dec 21, 2009 | 08:42 PM
Cooper24's Avatar
Default '96 scrambler 400 rear brake issue
My foot pedal for the rear brake does not actual the rear brake, however, the handbrake does work it normally. I looked at a parts diagragm and it appears I should be able to pull the back of the caliper off and there are some parts inside. Can I safely remove the arm from the brake and fix it without brake fluid or something else coming apart? Is there a common part that fails?
Also, the brake disk is not tight on the shaft (quite loose, flops around). Is this normal or should I replace it? My rear brakes work perfectly (besides the pedal), but seems like it shouldn't be that loose.
Old Dec 21, 2009 | 09:21 PM
ftwflh's Avatar
The sprocket should float on the shaft.
To get the rear brake to work adjust the jam nut on the end of the lever.
skinnyr6
Aug 25, 2023 02:18 AM
rcappie4
Jul 10, 2015 04:54 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
Rider252
Jul 6, 2015 03:37 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
