Polaris Wheel Spacer Info
Old Dec 29, 2009 | 03:48 PM
heyketz's Avatar
Default Need Polaris Wheel Spacer Info
I put some wider tires on my 2005 Polaris Sportsman 500 HO and they are very close to the tie rods. Looks like some 1 inch wheel spacers might be needed. I know nothing about them and am looking for info on bolt pattern, material (plastic, aluminum, steel). I think the bolt pattern is 4/156 but am wondering if any wheel spacers with a 4/156 pattern will fit on my Sportsman.
Thanx for the help......
Old Dec 29, 2009 | 04:22 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
pretty much all sportsmans are that bolt patten.
Old Dec 29, 2009 | 04:57 PM
Yep, you got the right bolt pattern. Just be careful on how wide you go if you have gates on your trails. I think your Sportsman would end up being 51" wide if you go with 9" wide tires with 1" spacers. The 1" spacers are as narrow as anybody makes them.
Old Dec 29, 2009 | 09:21 PM
heyketz's Avatar
So, I guess my question is will ANY wheel spacer with a 4/156 bolt pattern fit my 2005 Sportsman 500 HO?
Thanx Again...
Old Dec 30, 2009 | 04:30 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it should.
Old Dec 30, 2009 | 09:00 AM
EPIChad's Avatar
In wheel spacers there are two main things. #1 is the bolt pattern, you have to order one to bolt onto you size pattern which should be 4/156. So anyone with that size should bolt on and work. #2 is the width you want which is normally from 1" to 2.5". The other options are more for cosmetics or weight differences like steel or aluminum.
Old Dec 30, 2009 | 12:23 PM
heyketz's Avatar
Thanks to all who replied. Bought a set of 1" wide - 4/156 bolt pattern on ebay.
Evan d
Jul 7, 2015 02:36 PM
kwackermann
Jul 6, 2015 11:01 AM
VRRRRT
Jun 27, 2015 09:38 AM
bonanza 440
Jun 26, 2015 10:01 PM
Dieseltrash
Jun 1, 2015 06:53 AM
