Polaris Wheel Spacer Info
I put some wider tires on my 2005 Polaris Sportsman 500 HO and they are very close to the tie rods. Looks like some 1 inch wheel spacers might be needed. I know nothing about them and am looking for info on bolt pattern, material (plastic, aluminum, steel). I think the bolt pattern is 4/156 but am wondering if any wheel spacers with a 4/156 pattern will fit on my Sportsman.
Thanx for the help......
In wheel spacers there are two main things. #1 is the bolt pattern, you have to order one to bolt onto you size pattern which should be 4/156. So anyone with that size should bolt on and work. #2 is the width you want which is normally from 1" to 2.5". The other options are more for cosmetics or weight differences like steel or aluminum.
bonanza 440
06-26-2015 10:01 PM
