2008 Sportsman 50 hour flasher reminder
Old Jan 8, 2010 | 08:41 PM
SageBoy's Avatar
Default 2008 Sportsman 50 hour flasher reminder
Greetings,
My 50 hour reminder is flashing away and was wondering if anyone knows what combination of controls will disable the reminder. The 50 hour service was done before the actual 50 hours occurred so the dealer never had a chance to reset the timer. I looked through the manual but couldn't locate the info if it's in there.
Thanks in advance.
Old Jan 8, 2010 | 09:31 PM
Big-O's Avatar
Here is what the Manual says. Toggle to service interval mode and then hold mode button in for 7 seconds until the word OFF appears in the rider information center. You can leave it off or wait 5 seconds and then press the mode button until the wrench Icon flashes, then press the mode button again to set the desired service increment, then release the button and wait until the wrench stops flashing.
Also if you do not no how to get to the diagnostic mode do this. Turn key off wait 10 seconds and turn it back on while holding the mode/reverse override button. It will need to be in neutral with the park brake set. Hope this helps
Old Jan 9, 2010 | 08:31 AM
SageBoy's Avatar
Thank you for your time. For some reason I could not locate that informatio.
Old Jan 9, 2010 | 09:23 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
try looking at your owners manual under "features and control" section. look for "instrument cluster" then "diagnostic mode". it spells out the ways to check everything and not just the hour reset. it should be around page 50(at least in the 80o manual)
Old Jan 9, 2010 | 12:39 PM
Big-O's Avatar
Glad I could help. What I sent was out of the Service Manual not the owners manual, but Stendori is right the owners manual has it also just not as much detail if I remember correctly.
Old Jan 9, 2010 | 12:48 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
ya it pretty much tells you how to do it but sometimes they can be vag on thier description
GregM
Mar 6, 2018 06:53 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Sandman2.0
Jul 21, 2015 09:03 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
