98 454 speeds up when warm
Old Jan 9, 2010 | 10:20 AM
Darwinkle's Avatar
Default 98 454 speeds up when warm
The engine on my '98 Cat 454 speeds up dramatically when it wams up. It Idles and runs fine for a while and then winds up to the moon which makes putting it in gear a real "experience".
Is this a carb adjustment? Any help appreciated.
Darwinkle
Old Jan 9, 2010 | 12:06 PM
swampyjunior's Avatar
It is either an adjustment or a cleaning. Engines usually wind up some when they are leaned out.
So either your idle is too high. Idle speed changes slightly as it warms up OR you are having fuel restricted some how. (Blocked jet fuel line or kinked /plugged vent tube)
Swampy
Old Jan 13, 2010 | 09:34 AM
davethegunman's Avatar
I agree with swampy, also check the tube from the carb to the head, if it is cracked it will let air in and lean the mixture as well.
Old Jan 13, 2010 | 09:52 AM
TLC's Avatar
TLC
Time to take the carb of and clean it, and make sure the intake rubbers from air box to carb and carb to motor are air tight and clamped good.
A quick test is spray some ether starting fluid at the carb intake connections if the motor races then there is a air leak. a CV carb must have no air leak to run right.
Old Feb 10, 2010 | 07:05 PM
Darwinkle's Avatar
Wink Engine Speed Up Problem fix...maybe
I was doing some service on the beast and it took quite a bit of coolant. With the radiator topped off the engine winding up has dissappeared!
I hope that did it.
Thanks.
Pehter
Oct 3, 2024 11:00 PM
IMLN
Sep 28, 2015 03:32 PM
ReconBayou
Sep 23, 2015 02:41 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
