250 started,,,no throttle
Old Jan 13, 2010 | 03:24 PM
rwea14's Avatar
Default 250 started,,,no throttle
So I got my trailboss started and it will stay that was until i either give it some throttle or put pressure on my break handle....and also when it will go W.O.T i see some sparking coming from the exhaust right behind the heat shield...wondering if that would contribute to the lack of power and why would pulling the break lever cause an interruption in the throttle...thanks in advance...
Old Jan 21, 2010 | 06:06 AM
rwea14's Avatar
any guesses on brake lever??
Old Jan 21, 2010 | 08:13 PM
ctdnwakulla's Avatar
Does the engine shut down when you apply the brake?
Old Jan 21, 2010 | 09:10 PM
rwea14's Avatar
yes it will bog downtil it stalls or i let up on lever???? u may have an idea??
Old Jan 21, 2010 | 09:19 PM
TRX1000's Avatar
i would try and find out extactly where the sparking is coming from. mabey electrical? when you rev the motor the viabration causes a wire to short out on something. and when you hit the brake lever it activates the brake light, causing current flow to a short. just my .02, hope you get it figured out!
Old Jan 21, 2010 | 09:28 PM
I agree with TRX. is your battery charged and/or charging system operating? If not the brake light may cause the ignition voltage to drop. Try unplugging the brake light at switch and see what happens.
Old Jan 22, 2010 | 05:13 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
agreed. you sure the charging system is working on this bike? the only way the brake could effect it is thru the brake light it slef due to a short or drawing power the bike isn't putting out.
Old Jan 22, 2010 | 06:22 AM
rwea14's Avatar
well i will say that it needs a new battery as i have to jump start it every time as it does not hold the charge...I am getting one this weekend so I will check this out ,,had suspicions all along that may be the issue..thanks as always guys
Old Jan 22, 2010 | 04:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would be checking the output voltage w/ a meter to see if it's even charging and go from there before i buy a battery.
Old Jan 22, 2010 | 05:11 PM
rwea14's Avatar
have to plead ignorance on that one can you give me a quick step by step if you have a moment
