01 Polaris xplorer kill switch bypass
Old Jan 14, 2010 | 07:28 PM
NCHawk's Avatar
Default 01 Polaris xplorer kill switch bypass
I'm having some problems with the throttle kill switch on my xplorer. Can anyone tell me how to bypass it so I can get spark back?
Old Jan 15, 2010 | 04:44 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
are you sure it's not the etc that is not the issue? make sure you have about 1/8" slack in the throttle cable at the throttle so it won't kick in the ect override. just a thought.
Old Jan 15, 2010 | 09:00 AM
TLC's Avatar
TLC
Here is a video on what he is talking about.Polaris ATV Thumb Throttle Maintenance Tips: Polaris ATV Maintenance & Repair Tips | eHow.com
Old Jan 15, 2010 | 09:55 AM
NCHawk's Avatar
Thanks for the replys.
Its not the adjustment, its the assembly its self. So if I just cut the two wires that go to the contacts and put wire nuts on them, it should bypass the switch because it will keep them from touching? Correct?
Old Jan 15, 2010 | 10:02 AM
TLC's Avatar
TLC
Yes, take the two wire from the kill switch splice them together and its like the kill switch is off permanently. Just use the key to turn the ATV off.
Looks like there are more then two wire on that switch but 4
kill swich off is black wire to brown wire.
kill swith on is red/white wire to orange/black.
So I think you want to make sure black does not touch brown and then splice red/white and orange/black together.
ranvette
Jul 4, 2015 06:13 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
