Valve clearance?
Old Jan 17, 2010 | 01:17 PM
whyme26's Avatar
Default Valve clearance?
Anyone know the correct valve clearance for a Tao Tao 125H?
going to change the oil and figured while I'm doing things I may as well check this too... There is a bolt/cap on the top and the bottom of the cylinder head. I'm assuming this is where the valves can be checked/adjusted? Top being the compression and bottom being exhaust? Anything special I should know before looking at this?
Also, this is probably a long shot, but is there such thing as an owners manual for these Tao Tao bikes?
Old Jan 17, 2010 | 07:45 PM
OneTenCC's Avatar
Yep, those chromed circular caps with the hex heads on them is what you remove to access the rocker arms if I recall correctly. I PMd you a service manual.
Joel
Old Jan 18, 2010 | 07:42 AM
Faf's Avatar
Faf
.003" to .004" is what I have gathered.
Old Jan 18, 2010 | 11:17 AM
OneTenCC's Avatar
Not the same engine or vehicle for that matter, but basically the same procedure: MyChinaMoto.com - Chinese Community, Forum and News - QingQi (Qlink) 200GY Illustrated Valve Adjustment
Joel
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
