crank seals or carb??
Old Jan 18, 2010 | 03:11 PM
rwea14's Avatar
Default crank seals or carb??
I have been able to get my 1987 trailboss started now and it now idles and revs like normal. The issue now is when I get it in gear it will only go very slowly and if I hit the gas hard it just bogs down and stalls. I have unplugged the black wire on the rev limiter and it still did it. My thought is either the crank seals or the carb needs a good cleaning. Any words of advice....
Old Jan 18, 2010 | 03:37 PM
kaptinkaveman's Avatar
Had one of these in the early 90's. On mine the drive clutch spring had sacked out allowing clutch to engage too much too early. New spring solved this.
Old Jan 19, 2010 | 03:59 PM
tv4fish's Avatar
I would definitely dis-assemble/clean the carb first (much cheaper than crank seals).
Old Jan 19, 2010 | 08:14 PM
dirtjunkie's Avatar
it wouldnt hurt to do a compression test either
Old Jan 19, 2010 | 09:11 PM
ftwflh's Avatar
if it does it in gear check the secondary clutch buttons
clsharky
Jul 13, 2015 02:07 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Coryco
Jul 6, 2015 07:30 PM
