what tires fit
Old Jan 19, 2010 | 07:32 PM
fishycliff's Avatar
Default what tires fit
Have a 05 600 sportsman with 2 inch lift can i use 29.5/10.00/12 all the way around without issues
Old Jan 20, 2010 | 04:50 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you may have width clearance issues w/ out aftermarket rims w/ the correct off set. i think you can run 28" w/ the 2" lift but not sure about any bigger tires w/out a bigger lift. this is just guessing
Old Jan 20, 2010 | 06:18 AM
Kerbbirds's Avatar
The fronts will rub on the tie rod ends witout different wheels, a spacer kit or flip the end of the tie rod under on the strut and re-align.
Old Jan 29, 2010 | 10:22 PM
Amache's Avatar
Where is a good place to find Polaris spacer kits? Are there any that are less than 1" ?
Old Jan 30, 2010 | 05:36 PM
fishycliff's Avatar
found some on internet but none less than an inch
Alex G.
Sep 11, 2017 11:38 PM
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
