2002 250 Polaris Trail Blazer - Won't start with Pull Cord
So our starter went out on our atv and we are postponing the purchase of a new one, but purchased some more cord for the pull start - we're having an issue, it's not starting... it's making the sound as if to start but there is no firing up....
any suggestions?
i do know that we checked the spark plug and it's good....
as far as anything else... really have no idea what to check. this is our first atv that we've owned so......
any suggestions?
we checked the plug and it have good spark it run good until i stood it up on back tire to clean out the starter then found out it was burn out not dirty put it back in for now changed the coil rope and set it back down now wont start
if you didn't turn off the gas when you stood it up, then chances are you may have flooded it. gas will free flow into the engine if the needle opens ups in the carb because of the angle you had the bike sitting at. imo
