air screw on carb
Old Jan 29, 2010 | 04:13 PM
rwea14's Avatar
Default air screw on carb
have figured out that when my trailboss bogs down after a few seconds it is the air mixture screw backing out due to vibration..if i tighten it up to proper settings issue goes away..looking for ideas on how to keep it in one spot..think is the missing link to my finally taking a ride..thanks
Old Jan 29, 2010 | 05:03 PM
4getful2's Avatar
you could put a washer behind the spring,in case the spring has lost it's tension.
manufacturer's supply has rebuild kits for less than 20 bucks,and it looks like they give you everything, take a look-see.
You really don't want to put any locktite or epoxy on that screw.
good luck
Old Jan 29, 2010 | 05:33 PM
dirtsnow's Avatar
take the spring off & stretch it out a little bit that might help for a while, u may have to
get a new spring after a while, or might even have to get a little bit stiffer spring about the same size at a hardware store if the threads in the carb or on the air screw are
getting loose. I have had this happen on weed wackers before.
Old Jan 29, 2010 | 05:39 PM
rwea14's Avatar
thanks to the both of you,,i will take a look at the spring..hey forgetful,,finally got the clutches right,,took off primary and got it cleaned and it works well now...just have to fix the air screw and get new air filter..thanks for earlier advice.
Old Jan 29, 2010 | 07:13 PM
ddesens's Avatar
Put some blue loctite on the threads and let dry overnight.
Old Jan 30, 2010 | 04:16 PM
4getful2's Avatar
you're welcome,we knew you could do it.
Don't put any locktite of any kind on the carburetor. the metals are too soft and you may need a readjustment later.
Let us know how it runs when you get it back together
Old Jan 31, 2010 | 07:32 AM
rwea14's Avatar
put everything back together and it ran fine for a minute and than started to bog out again,,,i think it may be the fuel filter and line...i saw what appears to be a small leak either in hose after filter or at connection to filter,,filter looks a bit old and i feel like there is not a consistent fuel suppy,,there may be pockets of air until the nest pocket of feul comes in...those are my thoughts..waiting for my new air filter too..
slowgsxr97
Mar 18, 2022 03:40 AM
Aitch
Jul 21, 2015 09:40 PM
ghost civic
Jul 20, 2015 12:36 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
