2005 Polaris Scrambler 500 problems. PLEASE HELP!
My 05 Scrambler 500 4x4 runs great. But when i starts to warm up, my centrifugal clutch seems to be slipping. I can smell the belt burning. Is my clutch shot? How can i test something to see if my clutch is no good? When the quad is first started it runs great and the clutch doesn't slip at all, i have plenty of power. The belt on it seems new. What kind of belt should i have on it?( The belt on it now has ribs only on one side, and the ribs are facing in). When the quad is worm i have to give like half throttle just to move the quad.
are there any ways that u can tell me that i could test to see if my clutch is no good. And im pretty sure it's not my front clutch it's my back clutch. Like once it is warmed up ( i ran it w/ the cover off) the rear clutch seems to jam a little and it doesn't open and clese like it's sapose to.
What does the belt look like? Worn at all?
It may just be the belt going bad. When you pulled the casing off, was there any black dust buildup in there?
I had to replace my buddies belt because he was not using low gear to pull stuff and he burnt the belt up. Once you wear it out, it is going to start slipping.
