sway bar mod question
Old Feb 10, 2010 | 06:27 PM
jmarkle24's Avatar
Default sway bar mod question
Just bought a set of bighorns for my 550xp. I did the sway bar mod (24 3/4" outside to outside) but was wondering how much clearance is needed with the bike sitting on the ground? I have more on the left side than the right side but it doens't seem like much.
Thanks
Old Feb 10, 2010 | 06:45 PM
nc porider's Avatar
as long as you have clearance with it jacked up( thats as close as it's going to get) you will be fine
Old Feb 10, 2010 | 06:46 PM
lovmudd's Avatar
I would say a 1/4" on each side would be good. It comes down to what you feel comfortable with to have peace of mind. Mud build up is another consideration on how much clearence you want.
I over did it on mine and had to remove my muffler and aluminum shield to get the bar back in place, so I have way more than enough.
Old Feb 12, 2010 | 03:14 PM
HIGHOCTANE's Avatar
Yep...jack it up and let the rear suspension hang and you'll see the clearance at its tightest. I would want at least an 1/8th or so with the rear hanging..that will give you more than 1/4",probably closer to 3/8" sitting static. But as long as it isn't rubbing when the rear suspension is extended you are good.
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
