97 Xpress 300 - Rear Brake Adjustment
Old Feb 25, 2010 | 05:32 PM
Nandy's Avatar
Default 97 Xpress 300 - Rear Brake Adjustment
I bought this 4wheeler a couple of days ago. The front brakes do stop the unit althougth not to fast. It takes a bit much more to stop the atv than what I would like. The rear brake is pretty much useless. I can see pad left but not being familiar with atv pads im not sure if it is enough. Also the level travels quite a bit before the brake actuates. Is there an adjustment I can make? There is a bolt in the caliper but im not sure. Here is a pic of it.
Thanks!
Old Feb 25, 2010 | 06:07 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if i would have to guess not knowing that set up, i would say the stud w/ the locking nut would be screwed in (small amounts at a time to check) by loosing th locking nut. imo
Old Feb 25, 2010 | 06:28 PM
Nandy's Avatar
Anyone with experience on this set up? I dont want to go around turning bolts unknowing of the effects.
Old Feb 25, 2010 | 07:38 PM
Nandy's Avatar
BTW, they are hydraulic brakes.
Old Feb 25, 2010 | 07:43 PM
Just loosen 7/16" locknut on end of brake caliper as mentioned,turn bolt in until you have about 3/4" from the bottom of the brake pedal to floorboard when fully depressed,keep bolt from turning further and tighten locknut. Hopefully caliper piston wont be frozen. OPT
Old Feb 25, 2010 | 07:48 PM
Nandy's Avatar
Thanks OPT. Can you look at a thread I just started. I hate asking directly and I understand if you cant look at it.
Thanks...
http://forums.atvconnection.com/pola...ml#post2899439
Old Feb 26, 2010 | 04:38 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i was pretty sure it wouldn't hurt anything and it was going to adjust your brakes.
Old Feb 26, 2010 | 07:50 PM
Nandy's Avatar
Stendori please dont take offense on my previous and present post. I appreciate your desire and willingness to help. Trhu the time I have learn that many good people try to help and sometimes post advise that is really just a guess. I have tend to read trhu those and pass on them. By your own account you wrote that you are guessing and not familiar with the set up then close with a "imo"... That is why I passed on it. Now, it seems to me that is was an educated guess.
I will try to adjust it tomorrow.
Thanks both of you.
Old Feb 26, 2010 | 09:09 PM
Nandy's Avatar
BTW, the front brakes will not stop the atv when I use that little latch in the level that I supposed should work as an emergency brake. Where is the adjustment for that brake? I will probably bleed all of the old oil tomorrow after setting the brakes but it looks like it needs adjustment. It felt hard compared to a 500 that I checked today at a shop.
Thanks for all the help.
Old Feb 27, 2010 | 07:47 PM
Nandy's Avatar
I did adjust the screw on the caliper and got it much better. I did bleed the front first then when I went to bleed the back the bleeding bolt was frozen bad and I could not tell that it was not moving until it broke. So no bleeding the rear brake and hopefully I wont need to in the close future as now I have no way to do it.
