'96 scrambler 400 front 4wd hub
Old Feb 27, 2010 | 08:27 PM
Cooper24's Avatar
Default '96 scrambler 400 front 4wd hub
I noticed riding in the snow today that my right front wheel was not engaging. After running around a little and going front and back, it began to engage a little but it is still not right. I am going to tear into it tomorrow and don't have a manual. I checked the exploded parts list on BikeBandit and looks like there is a mechanism in there for the 4wd part. Hope I can just clean and lube it up. Any help or recommendations appreciated.
Old Feb 28, 2010 | 06:32 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
whens the last time you change the hub fluid it needs to be changed once in awhile for proper working using the correct fluid as well. if the wires going down to the hub are good then a good cleaning might do the trick. imo
Old Feb 28, 2010 | 04:37 PM
Cooper24's Avatar
thanks for the info.....I just got it about a year a go and still learning all the things that need to be done....fluid has never been changed....when I pulled it off today, I noticed there wasn't any fluid in it, but could tell there should be...I'm guessing the fluid is what causes the hub to lock out somehow.....there doesn't seem to be anything mechanically wrong inside, however, it looks like the rear seal is damaged. There is a coil wire that looks like it should wrap around the rear seal to keep it tight and it was pulled out and was flopping around.
what do you mean by two wires? I didn't see any....anyway, is the hub supposed to be completely full?
Old Feb 28, 2010 | 04:58 PM
Cooper24's Avatar
I think I know what the wire that was wrapped on the inside of the hub - I think it is a piece of the electric fence. that is most likely what cut the inside seal.
Old Feb 28, 2010 | 05:50 PM
TLC's Avatar
TLC
All there is to know about polaris AWD link. ATV Time :: View topic - Polaris Demand Drive Hub Q&A Picture Guide to Service
Old Feb 28, 2010 | 08:53 PM
Cooper24's Avatar
Thanks....that's what I was looking for....I'll update once I'm finished
Old Mar 27, 2010 | 06:35 PM
Cooper24's Avatar
posting an update.....I found the two wires going done to the hub got severed by the electric fence wire. Fortunately there was just enough sticking out to solder the wires back together. A little tricky but I got them soldered. Then I couldn't figure out why the little plate wouldn't lock up when I pushed in the switch. Doooh....has to be in drive! All I have left to do now is to secure the wires with some of that blue gasket material. At least that's what it looks like was used before. Thanks for the suggestions.
scram5050
Aug 30, 2024 01:39 PM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
